When I bought my vert 3 years ago, the driver side front window had the issue where it would go part way up, then drop down again. I was all ready to buy a new motor until I changed jobs and the BMW sat idle due to company car. Then when I went to start using her again, the window would occasionally jam, ie press to drop the window but other than a click from the relay in the door, nothing happened. It tended to just need a short drive and a couple of bumps and it kick started in to life. Then the more I used her, the whole fault cleared, even went up in one go without dropping again.
Anyhow, she's probably been sat for about 2 weeks and the window is again stuck solid. Despite a 4 hour drive, the window will not move. Doesn't even drop a fraction when opening the door.
Does this sound like a new motor needed or might it be more than that? I can still hear the relay click in the door, just no movement. Need to get this fixed as I had to have the windows up for all the journey because a vert looks stupid with just one window up and the roof down.
