1989 E32 735 - Charging problem
Ok i've really screwed up the wiring in this thing somewhere. My charging system is inop. I have tested the batt and gotten a free replacement for my alternator installed so we can rule out those possabilities. I have tested and checked the two fuseable links near the battery. I have also tested voltage at the rear of the alternator. On a charged battery and running I have battery voltage on the charge side and about 3% less at the field wire.
Here's the kicker.... I have no batt/charge light on the cluster anymore. Not before, during, or after starting. It just never comes on anymore not even when I first start. I have canged the bulb with a known good bulb and still nothing. I am tearing through the wiring diagram and see that this light runs from fuse 17 (which I have replaced as well as 26 and 28). Anyway.... Please help!!!!
89 735 by the way
89 735 by the way
