(Car has full and proper service history and just turned 70,000 miles)
Description of problem:
1. I start the 840, drive normally, at low revs, I could drive for 200 miles at 60 or 70 mph with no problems;
2. If I use kickdown and really start to use that M62 engine, within a few minutes, I feel a slight loss of power and the engine is running not so smoothly. It is now almost impossible to get the car over 100mph;
3. I bring the car back to base and it is now idling unevenly as if one or more of the cylinders has dropped out;
4. I go out to car the next morning and all is fine, all 8 cylinders in harmony;
5. Symptoms will return if I demand high performance as in step 2;
6. Plugs, plug coils, mass air-flow sensor, oxygen sensor, crank sensor - all checked or replaced - engine pressure tested - all in order;
7. Computer reads "misfire on cylinders 5 and 7, possible catalyst damaging;"
8. Has anyone got any suggestions about what I should try next? Some friends have suggested a restricted fuel filter, restricted injectors, or a catalyst on its way out.
I will be very grateful for your thoughts on what I should try next.
Many many thanks,
Lloyd
Many many thanks,
Lloyd
