1 - 9 of 9 Posts
HI all
had a diagnostic scan done
fault code pie25(could be p1e25) speed sensor monintoring
can any one shed some light as to what this is it an abs sensor code
530d se tourer
many thanks
hugster
You would be driving a BMW:lol
We need for Boostist or Ronnie to post up the meaning, they have loads of data that should help you out:thumbsup
Bimmerforums Central
Hi all
have googled this code comes up with mg rover camb sensor
now i am confused
hugster
Hi Hugster
Who gave you that fault code?
its not a BMW code that I have ever heard of.....as BMW codes are normally numerical only.
eg/ 225
20
etc
It may be a code that is specific to the hardware the garage was using to fault test the car.
Can you more importantly clarify what is the problem with the car?
What warning light is on?
I will then confirm the fault code on my BMW TIS
Discussion Starter #5 (Edited)
Hi boostist
abs light and traction control light are both on
sometimes stay eluminated from start of engine
other times just come on whilst driving
hope this helps
hugster
Hi boostist
hope this helps
hugster
Hi Hugster
I had this happen recently on my 535i took it to my local garage which use a Snap On Solus OBD this told them that my front left ABS sensor was faulty, replaced with new BMW part and lights reset themselves.
Need to get it on a code reader, they are very usefull tools.
Hugster what year is your car? Please fill in your car specification box:thumbsup
1 - 9 of 9 Posts
