i have just bought a 1999 T reg 318i se that i am over the moon with, only that the screenwash indicator is constantly lit, i have already tried changing the level senser at the bottom of the bottle but to no avail, hopefully some one can point me in the right direction. Also once i start the car without putting my seatbelt on the light comes on but then goes out is that normal or should it stay lit until i put the searbelt on, i have tried driving around to see if it comes on after a set time to remind you, your thoughts would be greatly appreciated
thehead
The seatbelt light doesn't work on e46 BMWs. It's not like Volvos, It may be a different case in the US but I've never seen one here work.
What happens if you leave the ignition on for a minute and then turn it off and lock the car then try it again later? Is it still on? (Same procedure for resetting the brake pad light)
have tried leaving the ignition on for about two minutes as suggested then locking the car but the lamp remains lit
