Not so, I had a 97' E36 316i saloon, and that was a 1.8, confirmed by BMW, it was one of the last made, and they used up the 1.8 block in it apparently.if it says 318 then its 1.8, if its a 316 its a 1.6. hope this helps
thanks, interesting what you said, cause apparently that is what this one was "meant" to be, a 316 end of line with a 1.8 block in it, though i was never sure, and as it was imported its a pain to trace. mind you bmw could probably find out... but at what cost lol
just looking on fleabay at a 1.8 block, looks identical to the 1.6 block from what I can see, hmm.... ill look for the number on the engine later...
