Just did a "how to" on this, hoping the pics come up in order with text, and waiting the mod to approve
Now if someone can shed some light on this subject and help me out. My pressure gauge reads this. starting at cold, pressure up to 3 bar. At operating temp, pressure a idle is 0.5 to 0.75 bar. 1500 rpm at 1 bar, 2000 rpm at 1.5 bar, 2500 rpm at 2 bar, 3000 rpm 3 bar, and at full throttle between 3 and 4 bar. Are these figures normal? the other things is that after startup, car needs some time to get any pressure at all. If car is off for 1 min, starting it brings my pressure up straight away. if off for 10 min, it takes 1 second to build any pressure. If off overnight it needs 3 seconds to build pressure. Now, this was the case even before i added the gauge, since my idiot light told me the same. After installing the gauge, took the car for a spin and wanted to see what the pressures were with the mobil1 5w30 oil were, then changed the oil to mobil 1 0w40. At normal op temps, 0w40 has a little more pressure, but the cold starting showed the same results as the 5w30. With both oils i get no pressure at startup, for how long, depends on how long the car was off. What could be causing this? any help appreciated=-)
