Hi All,
I have a e39 528 98 on a R, since owning this the alarm has never made any sound, the indicator lights flash to comfirm set and also if it is triggered but that is it, i can not locate any sounder of any description unless it is well hiden or does it just use the horn to create the sound.
Any help and pointers will be greatfully recieved.
T.
Where am i likely to find the siren, i just want to check to make sure it is actualy there or it has not been disconected then i will try the diagnostic route.
Might want to have some diagnostics carried out on the EWS to see if the siren comes up with a fault.
I presume the siren is battery powered or backed-up? like audi tt ones that fail - so maybe that has spilt the beans over the circuit board? Either that or wiring to siren or siren itself is fooked.
If you cannot find the siren then Neal's advice is your start point.
