hi folks im new on the forums,glad to be a member
i have a nightmare cooling problem on my 98 523i after driving more than 20-30 miles the car starts to overheat with MASSIVE pressure buildup in the hoses and expansion tank which can only be resolved by leaving overnight or bleeding.
i have changed the water pump and gasket,thermostat and housing + seals,viscous fan and tested the aux pusher fan which operates normally to no avail.
i first susspected a leaking head gasket but there is no white smoke from the exhaust,plenty of heat in the cabin until it starts to overheat,and cruicialy no mixing either on the dipstick,oil cap or in the resovoir also car has loads of power when running ok.
i have bled the system numerous times on an incline with the cap off and bleed srew removed only to sort the problem out for a few days also there are no leaks in the morning on the garage floor it only leaks from the reavoir when the pressure builds and it overheats.....
it all seems fine then the temp starts fluctuation only for it to shoot into the red after a few miles,strange thing is some days its fine with no problems,i have noticed a faint smell of collant in the cabin from time to time..
im at my wits end as i cannot think of anything else that needs replacing even my local indie mechanic is stumped insisting that its just trapped air....
if anyone has had similar problems please share... as i love these cars .even guesses lol would be cherished as the next step is just to scrap the car or the head gasket will make that decision for me real soon lol....
