The raise and lower system has an intermittent fault. When I raise the front n/s window it goes up 6" and then lowers. If I repeatedly jab at the switch, the window will eventually close shut. The window lowers with no problem.
When the window is "helped" to raise by gripping and pulling the top of the window when operating the switch it shuts OK.
Sometimes the window raises and lowers without any problems.
I have tried to programme the lower and shut points by holding the switch for 30 secs., but this does not solve the problem.
Any advice please?
I have moved your thread to the correct forum section:thumbsup
Sounds like your runners may be sticking. the door card will need to be removed to investigate further:thumbsup.
If you put the window up with the door open does it still have the same problem?
I have this with my M3 saloon, will fully close then drop back down a couple inchs. I find mine works fine when I press the button again so not really looked anymore into it.
Interested to know what it is tho.
