1996 E36 Compact - Idle hunting / Possible power loss
Hi guys,
Picked up my E36 Compact a couple weeks ago and very impressed with it so far! However, I've got one little problem that I'll try and explain:
- On starting the car from cold/cold-ish it seems to have trouble sitting at the usual idle RPM (just below 1000). It seems to jump up to about 1,500 then dive down to 500 a few times. Lately it's been tending to stall instead of bouncing back up unless I give it some throttle.
- I've seen the same thing happen to a lesser extent when stopped at lights, counter heads up to about 1200/1300 revs then a slight dive before back to the normal idle.
- Slightly more serious, I've had the car seem to drop power for a couple of seconds just after a gear change around town a couple of times, usually from 2nd to 3rd (changing at what I'd consider normal speeds).
Looking around the forums, am I right in saying I should be checking the air flow systems (pipes etc) first of all?
Cheers,
Paul
Hi guys,
Cheers,
Paul
