I'd recommend buying....cough....downloading..... a copy of the Bentley Manual.
From memory you need to remove the bolt on the slider adjuster on the b pillar. Pull back the door rubbers and window rubber and remove the plastic trim and then you will be able to get at the seatbelt mechanism.
Its easy as mate as above you cant go wrong.
