since i bought the car (318is 1998) it has had the worlds most annoying squeak at the steering wheel,
i changed the ribbon behind the steering wheel with no change, and also lubed the top bearing, turns out it's the bottom bearing in the steering column which is near impossible to reach,
so i have drilled a 2mm hole about 3 inches from the bottom of the outer column (slowly and carefully) and sprayed in grease (a can with a pipe in nozzle) the squeak has gone immediatly!!
took 10 mins to fix and £4 for the spray grease!! peace at last!!!!
