Banned
Hi all
My car has developed a fault.
It’s worse in first gear but does happen in second and third. When the clutch has been fully let out and I apply the accelerator the car starts to Kangaroo to the point where you have to lift off the accelerator and re apply it more slowly. The more gas you give it the worse it is!
Any ideas as to how to solve this problem?
Thanks Whacky
Banned
Thanks mate I will do tomorrow when it’s light, it had a pipe come off a couple of months ago and that just made the car refuse to idle. I thought a split in the pipe would do the same so had ruled that out in my mind. But that is a good a place as any to start with.
Whacky
Ok problam sorted it was the air pipe from the mass air flow meter to the manifold. It had a big split in it. Just incase anyone else has the same problem.
