Hi thanks for the reply, googled and found with the standard 17s on my z3 2.8, the offset is 41mm front and back, so what do you think i could go up to without any rubbing on standard suspension cheers.
well ive done 8.5x19 et40 front and 9.5x19 et45 rear on a normal body z3 using 235/35/19 and 265/30/19 tyres.
if your car is say an inch or so wider i would say you may be able to use et25 off of a e46 m3 for example but without seeing or having measurements i wouldn't be able to give you an exact answer.
