Hello , I have a 1998 728 which as been laid up for a few weeks , was running runnining 100% till parked up but now it just turns over and does not even try to fire up ,, any ideas ?? crank sensor ? many thanks .. P.S .. Where is the pos of the crank sensor ?? thanks
The first thing you need to check for is if you have fuel and spark, when you have done this we can move on :)
Try removing a coil and plug, put the plug in the end of the coil and crank the engine over with the plug about 6mm away from a earthing point on the engine.(careful you don't shock yourself)
Can you here the fuel pump prime up in the tank when you turn the ignition on?
Try removing the fuel line and crank the engine over with the fuel line in a bottle
