hi
i recently hit my 318is into a kerb, and the wheel is now bent.
on inspection the bottom control arm was bent i have changed this however the wheel still, is bent slightly.
is it possible the trailing arm could have also bent slightly?
also the driveshaft from the outer joint sometimes works and sometimes just spins, is it broken or have the splines in the shaft just separated?
any help would be greatly appreciated.
