happy new year to you all :cheerful
e36 m41 engine
heater water valve has been ticking like a relay for a few months and now has stopped, along with the hot heating air from the vents.
rebled the system and still cold, temp is normal and sits in middle for long driving trips
i believe thermo and water pump are working the top rad pipe is hot and the bottom pipe is cold. wanted to know if any one has changed a water valve or are theses common failures can they be opened and repaired ( not another replacement please)
i understand that the water valve controls hot water into the matrix is this right on the m41 tds engine?
i will double check the fuses and wires ( not today -1 outside)
e36 m41 engine
