Uber Platinum BFuk Member
hi, looking on ebay and found a set of wheels i really like but they say they only fit E46 bmw's? think they will be fine but just to make sure can anyone tell me if these will fit?
Rim Width: 8.5J
Tyre Width: 255
Rim Diameter: 18 inches
Aspect Ratio: 35 Offset: 35
Load Index: 97
Number of Studs: 5
Speed Rating: ZR: over 150 mph
Stud Diameter: 120
will i have an issue with rubbing as my cars lowered 60mm front and about 40mm at the rear?
many thanks :thumbsup
Rubbing more than likely on the rear if using an ET35 offset. You will more than likely need the rear arches rolled in order to gain as much clearance as possible.
I hope the 255's are just on the rear:rofl
yeh mate, there 8.5 at the back, i can raise the rear tho as there as low as the can go at tho moment so can raise them about 25mm+ :thumbsup
:duh sorry dude, couldnt find it so put in in brake and chassis forum :shifty:
It is a PITA because it's listed in a sub section in bodywork and detailing which is not yet visible when looking at all the forums:frown
