Morning all, sorry this is a first post and it's a problem one.
My 1997 320i Auto doesn't want to start. The car has always started on the botton until now with no running issues at all. She cranks over and over so I am eliminating starter or battery.
I have been reading up as much as possible and I'm starting to make checks but i'm not sure i'm on the right lines or not so i'm hoping someone could chime in and help me figure out what the problem is.
I've only looked at the following so far
Checked battery - it has good charge (12.3v)
Fuse #18 - Good
Power to Fuse #18 is 0.00 volts with ignition key in position 2 - should I see anything there without cranking the engine over?
here's my fusebox (upside down) i don't know what the relays are and how to test them as i guess that should be my next step. (Fuel and DME?)
If the fuel and DME relays check out ok then i guess i should start looking at fuel delivery and then spark.
Can someone help me figure out what relays are the Fuel Pump and DME and the steps i need to take to check them
Many thanks one and all
Fuse #18 - Good
