Hi
I have done a engine change 318i to 318is m44 1997 the car has a 5 point airflow meter on the car and the wirering loom for the 4 point and 2 more going to the front of the air box.Is it possible to rewire the harrness so i can have the 5 point meter with the 4 point harness and 2 wires to the front of air?
Thanks H
You should have changed the engine wiring loom along with the engine, then you would have all the correct plugs and harnesses, are those the only plugs you are missing currently?
