OK so today I have made my way back from Manchester to London and as I came through the roadworks on the M1 the temperature gauge started indicating that the engine was trying to be the Sunday Roast
So I pulled over, checked and found it was still full of coolant, as I came off the motorway the temperature dropped to 90 almost immediately. So thought I'd try and get home, turned the heaters up and set off. Got back the last 30 miles and bar one instance of it getting warmer again it made it.
So googled it on here, checked everything I can so far and just looking for a more definitive answer. The top hose could do with being replaced as it's looking rather tired (not a problem and will sort it). The car does have A/C so has the dual electric fan rather than full engine driven viscous fan. The car had a new radiator fitted shortly before I got it. It has been faultless for the last month since I bought it. When I got it back I left it idling for a while to see if the fan kicked in and it didn't. Googled and found a post on here about shorting out the fan to test it and rule out the fan or temp sender. So it would appear that the High Speed Fan works when shorted out (and when the A/C is on) however there is no sign of the low speed fan working when shorted out (pins 1 & 2 from memory). The relays are in the fuse box and I assume they are working (so far). Thought I would just give replacing the fan coupling a go but then when I realised it wasn't exactly cheap thought I'd check on here first.
So my question is, it it likely to be the fan coupling that means the low speed does not work but the high speed does?
