Hi all. I have the basic 7 button OBC that only show temp and time. If i replace with the the better 18 button OBC will the other functions work. is it a simple swap or is there more to it?:confused
Search is your friend! This has been discussed loads recently.
The swap isnt exactly easy nor straight forward, it involves ripping your dash apart to run new wires in, and I dont think youll have all the sensors, which you would need to install if you wanted all functions to work?
Ill get you a link regarding the retrofit/upgrade
