having just spent £1200 having head replaced i now have a autobox problem, it was fine when it went in but since it came out of garage its playing up.
initially when you put it drive you have to rev it for it to bite, when changing from drive to reverse the same thing happens, however not all the time. then came the autobox warning light, topped the oil and the light has gone out. it changes fine when in normal driving but if i was to stop then try to pull away it will bite but if i floor it it feels like its slipping. my initial thoughts are there is a vacuum pipe leaking or loose because selecting gear when idleing, but when i rev it it will bite, i also think it may be a blocked filter. has anybody had any similar symptoms?
I would certainly get the boix serviced asap - paid £145+vat to get mine done - but then I just got it done for piece of mind - but all was well with the box
