Hi there
I have been getting great help through this forum for a good few months now and had help fixing my issues but the most recent one has me stumped.
Sometime ago I had a fault on my dash, Traction control and abs light was always staying on the speedo wasnt working, my wipers were not working on high speed, the digital display couldnt tell me how many miles I have done and the wee MPG gauge under the rev counter didnt work either, even though the rev counter itself did work fine.
The car itself is a BMW 523se, V reg, its great to drive without any other issues.
I took onboard everyones advice on this forum and changed, what seemed to be the most popular fault, the speed sensors, I changed all four sensors on each wheel.
And guess what... the two warning lights are still there. Someone mentioned that even though the sensors are changed the lights will not go out straight away but will eventually go out when enough miles have been clocked up for the data to be worked out in the computer, but the fault would still be registered deep inside the computer memory, the fault itself will be sorted.
Is this true? Its just that I fitted the rear sensors a few weeks ago and fitted the front sensors yesterday, today I recon I clocked up over 100+ miles and the lights on the dash are still there. Is this normal for the computer to take so long to out the fault is fixed, or is there another sensor somewhere that I need to check? (there is no sensor on the diff)
I dont have the fault codes as the guy at the garage said that for some unknown reason he could'nt access the ABS module or something like that
Can anyone give me any help to sort this problem once and for all?
Many thanks
John
Many thanks
John
