im going to take a guess at this and assume that there is already a place to fit the windows as the central locking wires need to run into the same space, these are just a screw in fitment so if you can get the part that screws on from the donor car it should just work, might not but worth a try, if it dosnt its a fairly simple job to just wire up the windows, get yourself some wiring diagrams from the net and try and work it out
