can anyone tell me how to remove these front inner arche as i have 19"s on my compact and they scrape when turming. also will this affect anything if i have them removed!
you will get a lot of shit thrown up into the wing and cause it to rot, you wont know its happening and the whole wing will need to be replaced as it will rot from the inside, unfortunatly fitting huge wheels to cars mean you will have clearence issues, you might be able to get one made up or have yours modified in some way but i certinaly dont recommend you remove it
What width wheels are you running and have you determined where it is rubbing?
Many replacement BMW wheels rub the inner metal arch and I've even seen a case where the metal brake line was very badly worn through:mad
