hi, ive been looking at bmw 316i compacts (e36) and ive seen a seemingly good condition black one with some of the subtle mods i was thinking of already been done. lowered, sports rear light, new wheels, induction kit etc. bodywork and transmission seem to be in good order and the engine sounds and goes like its in good working order, the only problem being theres a lot of oil down the side of the block and around the sump and steering rack etc. it looks fairly old and baked on but im not completely sure. also there was also a bolt missing from the cam cover which suggests its had a new cam cover gasket which i hear is common. i was wondering if any of you know what could of caused this oil to be there ( its only down the inlet side of the engine) as im sure with the amount of oil thats there it couldnt of come from a leaking cam cover . cheers for help
EDIT.
I posted earlier after ive been to a see a e36 316i compact and there was alot of oil around the block sump steering rack area. ive now been told by someone that their sump gasket went on their 316i and they had heard its a pretty common problem although they weren't a mechanic so i was just asking on here whether this is a common problem and if it is, is there room to drop the sump down and to replace the gasket?
EDIT.
