My name is Tony and just saying HI!
Last night I took posession of a '97 1.9 Z3, 77k, black with hardtop + the obvious s/top, T&T until June and was my daughter's old car along with an Audi TT which she also owned but, she has now sold the Audi and bought a BMW X3 so, she let me have the Z3 for a very nominal sum so, I'm quite fortunate.
The Z3 seems to run very well but, is cosmetically in need of a little tlc and maintainance and I'm looking forward to getting my hands dirty in bringing it up to decent condition once again.
A few questions:
The heater/demister fan only works on the maximum speed (setting 5) while the other settings (1-4 don't respond) - am I right in thinking that the problem is a a resistor failure which causes the problem?
The symbol for airbag(?) is remaining lit - are there any known common causes for this? A car I own has a known airbag warning light problem that often occurs when the seat is moved regularly in that the snap connector under the seat occasionally works loose just enough to trigger the warning light - I'm just wondering if there are any similar known problems with the Z3 so that I can check it all out before finally, if necessary, taking it to a main agent!
I suspect the cam belt has never been replaced so this is number one priority after the airbag problem is sorted - what sort of time ( in hours) does it take to replace?
The wing mirror bases appear to have corroded(?) where they mount the outer skin of the door and have been re-touched relatively poorly - are they difficult to remove so that I can re-spray them properly or are they better off being replaced if available as a separate part?
And finally, the driver's seat ( black leather) is coming away along one seam for about 2-3 inches ( nearest door) - any suggestions for this as a temporary measure until I get time to find maybe a replacement seat?
As I'm new to owning a BMW, any other commonly known problems I should watch out for?
Sorry for the lengthy first post but I look forward to any advice you can give.
Regards...
Tony
A few questions:
Regards...
Tony
