Have a read here:thumbsup
Philthepower
Bimmer Fan
Philthepower's Car Specifications
Philthepower's Car Specifications Make of Car: BMW Model of Car: M3 Evolution Year of Vehicle: 1998 Transmission Type: Manual Car Body Type: Saloon
Vanos Rebuild
I had 2 Vanos units to choose from. It turned out the younger and better condition Vanos unit was the one from my second doner engine, even though I was unsure of the mileage. I basically just stripped it down and changed every single seal I was able to.
I wanted to be able to sell the other unit as a working unit, but even though it passed a vanos test just before the engine failed, the exhaust solenoids were damaged. So I put the younger solenoids from the unit I was using into this one, and forked out ~£230 on these...
First a picture of the unit before starting...
Everything removed...
Cleaned up...
New solenoids fitted with new seals and bolts...
Completed unit with all new seals, bolts and a new Vanos filter...
0)
Philthepower
View Public Profile Send a private message to Philthepower Find all posts by Philthepower Add Philthepower to Your Contacts
20
04-27-2009, 02:23
Philthepower
Bimmer Fan
Completing Engine
Next was just a case of finishing the engine by fitting the Vanos gears and unit and timing the engine up.
I have to say unless your a competant mechanic with the proper repair instructions, I wouldn't even attempt to mess with the Vanos in the way I have. Timing this engine up is probably one of the most confusing things i've ever done as a mechanic. The BMW reapir instructions are not very clear...at all, and I think I ended up timing it up 6 times in total until I was happy!
