Hi Guys i had a quick look couldnt find anything specific to what i would like to know.
I have done the binnicle test on the guages and they work fine, so i tested the resistances on both fuel sender connections and the one attached to the fuel pump (drivers side) i think is the one at fault cos there is no resistance at all from that one where as i get a reading from the other...
My question is-is the fuel pump and sender one unit with the fuel pump ? or are they seperate?
and if so how is the best way to change it ?
thanks guys :eek:)
Comes with the pump :frown
http://www.realoem.com/bmw/showparts.do?model=BK72&mospid=47421&btnr=16_0211&hg=16&fg=15
Try removing the pump unit and check the wires under the plastic top that sits in the fuel tank(the bit where the pipes join to)
http://www.pelicanparts.com/bmw/techarticles/101-Projects-31-Fuel-Pump/101-Projects-31-Fuel-Pump.htm or http://www.pelicanparts.com/bmw/techarticles/E36-Fuel-Pump/E36-Fuel-Pump.htm :thumbsup
Also when the pump is out you can check the sender properly, their should be a smooth change in resistance when you move the float up and down slowly
