Dear Forum'ers.
Further to my last post regarding the above issue I'm still having what seems to be a(nother) fuel related issue, any help as always gratefully recieved!
I've changed:
Diesel Tank Lifter Pump
Crank Sensor
Main Diesel Injection Pump
Replaced 2m Vacuum Hosing
Blocked off EGR Valve
My initial idle-ing and cut our problems have now been resolved (thankfully!) but now the car is 'holding back' when I put my foot down, usually it will eventually pick up and go, but not always. It just feels to me like it's not getting enough fuel under load? This is always noticable when going up hill or accelerating on a motorway slip road! But it does occur randomly under any conditions. When this happens the mpg needle wavers.
I was advised that the second hand Injection Pump may have been running on Veg Oil and could have 'sticking parts' inside which is the cause (?) so I'm currently running on a high dosage of Forte to see if I can clean it out. Maybe it's this, but could it be anything else? It seems once I fix one problem it highlights another.
My previous post is here:
http://www.bimmerforums.co.uk/forum/f17/1996-e36-325tds-engine-idle-cut-out-t71503/
Many thanks indeed in advance...any/all suggestions welcome!!
I've changed:
Crank Sensor
