Hi Guys/Girls.
I'm new which probably means I will be crucified for daring to ask something that is probably hidden away on some obscure thread that is impossible to find (joking)
I recently had some trouble with a rough and erratic idle when the car was warmed up. I put this down to the Idle Control Valve possibly needing to be cleaned.
I got a guide off an American BMW forum that I accidentally joined in error (hope no one else makes same mistake) on how to remove the ICV and after being totally terrified by the amount of stuff the guide said I should take off, I went and had an actual look at the location of the ICV and after removing the throttle body and inlet elbow for ease of access, was able to just reach under and remove it with the whole process taking less than 5 mins and without taking off the inlet manifold and fuel lines and what not. Refitting ICV after cleaning also took less than 5 minutes.
So anyone who wishes to remove/replace their ICV would maybe like to consider my approach which unless you have hands the size of dinner plates is far easier than spending 3 or 4 hours stripping down your inlet manifold and cutting rubber bits etc .
Well anyway now if anything the rough and erratic idle has worsened and I did notice as I was cleaning the ICV that there was no resistance in the little flap or gate type bit that obviously must open and close when required to. I'm wondering if this is normal and if the ICV unit itself is faulty?
Many thanx in advance for any info anyone can give and I do apologise if I've asked something that has been answered a million times but in my defence I did search the forums but found no suitable threads
