1 - 10 of 10 Posts
alright chaps i went to fill up today and after i left the shop my car was hot so i had it bled but its still getting hot what could this be my heater is very hot!!. could it be the viscous fan??
BFuk Legend
it could be,but it might also be a thermostat problem or blocked (silted up) rad...or indeed a broken/slipping water pump
(this is in the wrong forum btw ;) )
Ill second this:thumbsup
With the engine OFF check the fan by turning it by hand. If you feel no resistance or very little you will need a new fan. If you have not changed them, like Mark just said change the thermostat and water pump ASAP. Make sure you get a metal impeller pump from Gsf though. I really wouldnt drive it if it is overheating that much as these do not like getting hot :frown
alright thanks chaps there is no resistance on the viscous, and also i noticed a couple weeks ago the temp went down as i was goin down the M1:eek
Discussion Starter · #6 ·
Definatly change the fan coupling, stat and water pump Mainblazer. Shouldnt cost more that £100 from GSF. Its worth it to save future probs mate :thumbsup
yes mate i will take your advice they will be changed in the morning if euro car parts have the bits! thanks steve i had the overheating before but that was my cap for the expansion tank, the seal had gone! its definately a different fault lol:confused
Discussion Starter · #8 ·
Let us know how you get on. Just check the pump has the metal impeller before you leave the shop :thumbsup
Also remember to follow the advise on here about bleeding the system. :thumbsup
i will do thanks i didnt realise there ia a gsf near to me so i will get the parts from them! do you know if the prices on the site are + vat or not
Discussion Starter · #9 ·
alright chaps my car is now running sweet again tank you very much!! i changed what i was told and the problem disapared the parts were £101.86 from gsf. my friend fitted it all for nothing what a good mate lol well i sorted him a drink wicj he didnt want!! ;-)
1 - 10 of 10 Posts
