Status
Not open for further replies.
1 - 15 of 15 Posts
Lads,
On the M44 engine on the OEM intake box there is a electric sensor "thing" at the front of the box and I would like to know what it is and what it does
I have tried looking through RealOEM but to no luck...
I'll see if I can get a picture... to help what I am saying...
Discussion Starter #2
The picture
Its on the bottom right the little thing that is going into the air box!!!
actually, that aircon bit might have been for the part under it.....
Hard to make sense of really...
Because I cant see that channel plastic bit being a air con part :hihi
Please the MAF is a temp sensor any way right?
Say if I was to put a universal cone in then where does it go?
Not sure what it does but it measures something as when i got my K&N cone filter it had a section specially built into it for stabbing that in...
as shown here..
So what I would do, if the green filter is big enough, just drop it inside before you attached it all up or drill a hole on the side for fitting it. I never tried it with out the little sensor thing... so not sure what it controls... :confused
(though my gree iS didn't have aircon ether... but also..that doesn't make sense if it was for the Air con... its in the filter box that sucks in air for the engine... not air con.. :confused :confused
Discussion Starter #12
Discussion Starter #14
Neal Close this one up and I can jump on the other one! :thumbsup
1 - 15 of 15 Posts
Status
