Hi
when driving my 318is it randomly cuts out when driving doesnt matter what speed im doing or how many revs the engine is at when i go to restart it it runs like a bag of spanners (trying to die and back firing) unless i hold it above 3k rpm however (although sometimes if i hold the throttle still there is a bang and the engine fires back into life) i have noticed the car only does it when it is hot, ive been over the engine but i cant find any leaks, its not using any oil or coolant and neither is it mixing although the coolant is black but i only changed it a couple of weeks ago and it doesnt overheat
the problem is extremly random though it might be fine for a couple of days or it might do it 2 or 3 times in one trip. i took the car to the garage and had the fault codes done and when the car was driven again it ran fine untill the evening and it started playing up again. another day i was driving it the idle control valve died and the car started idling at 3k so i disconnected it drove home and reconnected it and its been fine ever since. im a bit confused to it all.
there seems to be a release of pressure sometimes from here aswell does anyone know what this is as i have never seen it on a car before. i spoke to a mate who had the same problems it turned out to be the idle control valve but his one cleared after a good thrash, i took mine for a thrash and the next time i started it it just ran like :censored again
sorry for the essay any advice is greatly appreciated
