Having recently acquired a 540i Touring I am trying to track down an air leak on the intake.
The symptoms are :
Misfire - very noticeable around 1200 RPM +
If I stab the throttle whilst the car is idling - it almost stalls before picking up
Very obvious sucking noise which appears to come from under the inlet manifold on top of the engine
Car has 122000 miles - new short engine at 41000
I realise this could be quite a tricky problem to trace - just wanted to see if there were any common failures to check first.
Any thoughts?
The symptoms are :
Any thoughts?
