1996 E31 840Ci - Suspension rebuild time... Shopping list
chaps
ok, so i think i'm going to have to bite the bullet and start investing some money into the 840. 3 out of 4 shocks are leaking and i'm getting some squeaks and rattles towards the rear of the car. im after help on the shopping list of things that i may as well replace while the thing is in bits.
shock absorbers are obviously on there, as are trailing arms bushes (as they've had it). the only other thing i have so far is top mounts. any suggestions would be most welcome. also, to anyone else who has undertaken this job... what sort of budget should i be looking at for parts (front and rear)?
ryan
I replaced my suspension arms and bushes on the front. Did it in two stages, uppers first then lowers. Cost about £150-200 inc labor for each pair to be replaced. The bushes can be expensive little buggers. I recall paying almost £40 EACH for a pair - which ones they were have escaped me though.
I'm starting to get a rattling from the rear end too. If you have EDC let me know how you get on with replacing the shocks, I've heard they can be perilously expensive.
ok got the wallet out today. im attacking the rear first, as its in need of the most attention. so far i've ordered:
2x shock absorbers
2x rubber top mounts
2x dust covers
2x trailing arm front bushes
2x trailing arm rear bushes
2x reinforcement plates
just a quick one... for the trailing arm front bushes (the ones with the axle pin going through them): do you have to have the special tool to get them out? i have access to a hydraulic press at a friends garage.
Not done it myself but im sure Pheonix Motorsport hire out a tool for it although i would imagine a press would do the trick but hopefully someone will give you a definite answer.
I used a press; you just need suitable pipe/socket/dolly to press them out.
and for anyone who is interested, said parts came in at around £500.
The shocks and springs work out cheaper when bought as a set of four; you know you are going to need them.
