the air con is not reliant on the ambeint temperature outside the vehicle - and it should be used both in the winter and the summer, the compressor fitted works equally well when heating up the interior as well as cooling it down. The worst thing to do is leave it switched off throughout the year and only use in the summer - as Ian S says it is a great demister......the refrigerant used in the system also carries a lubricant for the air con system so to keep it all effective it shoud be used as ofen as poss.....
