Hi a bulb has gone on the interior of my car. Its the one on the pillar on the rear passanger. Is it a case of removing the whole unit to get at the bulb or just the clear plastic panel?
Thanks Ben
You have to remove the whole unit out of the pillar linning to access the bulbs.
Use a VERY thin flat blade screw driver and wedge it in at the bottom edge of the light - essentially at 6 o clock - this is the location of the springs that hold it in.Wiggle around and it should pop the light out.
Once out you need to push the circuit board in one direction to release it from the light unit.
