Hello again,
Something to pick your brains about....
My ABS does not work, I have had the codes read which showed both front sensors as faulty.
Thats the easy bit.........
The bulb on the the instrument panel was dmaaged so I have replaced it with a genuine bmw part.
The problem is that it does not illuminate whatsoever, does not come on with ignition or when driving.
This is causing me hassle as it wont go through an MOT like this.
The other problem is that the bolt holding the wheel speed sensor in has snapped off in the hub... joy!
Any ideas on the bulb problem? Fuse under bonnet it ok.
