Please help me (again) guys.
The problem is that the heater only blows out Bloody cold air have an hour long drive to work and still only cold.
The temp gauge stays in the blue all the time no ,matter how long i have been driving.
What do i need to do.
Also as a side issue where can i get the little light bulbs from to go behind the switches
Could you remember to add the vehicle details in the thread title next time as per forum rules please, they have been done for you this time. It makes it far easier for people looking up help for their own problems or conversions. :thumbsup
As for your heating problem, It sounds like you need a thermostat, check the coolant level, I would also advise bleeding the cooling system first before condemning thermo, after bleeding run the car up and if the temp gauge doesn't go up like it should and top and bottom Radiator hoses are same temp then definitely thermostat :thumbsup
Euros http://www.eurocarparts.com/
GSF http://www.gsfcarparts.com/ both do them.
Bleeding...
