Hi can anyone help how do you take the bumper off m3 e36 on 95 plate as justbought it and wont to change the fog lights as they are cracked where do i find all the bolt thanks in advance :jaw-dropping
take the number plate off and then pull the trims off the bumper. u will find 2 13mm bolts either side of where the number plate would be, take them off. thats the main bit out the way, the rest of the screws are in the inner wheel arches which are clearly visable, and there are also some small screws underneath where ur m3 lip is, these are connected to the s*** shields. sounds alot of work but it dont take more than 1/2 hour
