hi all
i own a 1995 bmw 316i compact and have a starting problem
9 out off 10 times will start 1st time but now and again usaully when your in a rush lol you turn the key and nothing
i press the fob button this sometimes works if not i have to push start it
has anyone had same problem and how did they solve it ?
i was thinking starting with the starter relay but carnt find it so if you know were it is please tell
please help this is getting annoying now thanks for looking
Bimmerforums Central
hi all
Read the posting rules please
http://www.bimmerforums.co.uk/forum/f74/bimmerforums-uk-forum-guidelines-t2257/
I have renamed and moved your thread to the correct place...this time!
Banned
hi all
If you are able to push start the car, then it does not sound like an Immobiliser/EWS fault.........I'm guessing that you have a factory alarm/immob?
could be a starter problem or even a prob with the ignition switch.
The starters are pretty fiddley to get at on the beemers but what you need to do is find out whether you are getting a ground to the starter when turning the key.....if not then you would have a prob with the ignition.
If the ground does switch over to the starter when the key is turned to the start position.............your started is shot.
its an intermitant fault
sometimes if i press the alarm fob and retry to start it does then
sometimes if i just leave it for a while it starts i only push start it when im in a rush when it wont start
was thinking starter relay but can not find it looked under dash os and ns
The DME(ECU) takes the place of the starter relay on your car(in other words you have no starter relay, it's built in with the ECU)
Discussion Starter · #6 ·
thanks
thanks ive stripped me dash looking for the relay lol:confused
so im looking at ignition or starter then
the ignition does sometime turn (barrel turn)
and i can bridge the stater so does look like ignition which i take it that a new ignition is main dealer only?
Banned
On some models, ECP do ignition switches- worth a shot.
