(SOLVED) 1995 E36 328i se Saloon - Wiring and Alarm issues after fitting Auto-Dim Mirror
Right I decided to fit this....
Sparkys or who know everything lol please tell me why after I wired it up - every time I lock and alarm the car... 5 seconds later it goes off for no reason and also the main light for the interior dont work even though the bulb/led looks fine...
I'll show you the wiring... and how I done it...
everything is off
Here you can see the wires
Now here is the interior light wired with the Auto-dim mirror... and then I put the brown wire to the other brown wire to ground it out (Cant see that tho)
Then all finished...
Like I said... I alarm it and it goes off WTF please someone help me...
EDIT*** I forget to mention that the Auto-dim works!
Did you just twist wires together with your fingers?
Yes... I don't have a solder gun or anything like that...
A soldering iron is a lot cheaper like £5 to £10. Go get one.
Sounds like something is not working as intended probably due to reistance in the connections or a break - which explains the light out. You could have common earthing or all sorts of problems. Alarm probably going off due to a voltage drop.
You could always use crimp on connectors to join the wires instead of soldering. And if soldering get some heat shrink.
right... also just to add... my angel eyes on the NS dont work and niether do my tail lights :S
Fuse 33 (10A) has blown...
Just to confirm it was the 10amp fuse that was the issue... Cheers to E36Coupe328i for your help! and so quickly! :thumbsup
