1 - 11 of 11 Posts
Ive had a broken barrel for a few months now and now that i have ordered one from BMW finally I cant seem to get the old one out ive been trying for past 2 months with no joy and ive followed the video guide and still nothing
YouTube - BMW DIY #5 - SPINNING LOCK-
are there any more tips
can i just add the srew to stop my tumbler from spinning aand get normal operation back?
Ive just been outside and tried to remove the barrel and the steering lock has come on and wont come off HELP please
ive ised a allen key a bobby pin and really thick paper clip and a small screwdriver and nothing
I had the same problem with my mums old escort years ago. Doesn't matter what we used it was stuck solid. We ended up smashing it to bits to get it off in the end!
I know that's not what you want to hear but we had to!
Good news is i have figured a way to take off the steering lock and it was pretty simple and posibly a oversight by bmw but worked in my favour.
Is there anyone in my area who can do this able to come have alook
i had the same problem with mine mate what i ended up doing was putting a small bend in the end of the paperclip. the end you put into the barrel then when i located the release pin twiusted the paperclip and it freed it. it diod take me about an hour on the one in car but once changed it the new one come back out easier. i took the new out after fitting just to see how easy it was
ive tried and i cant seem to get that special spot I line up the barrel correctly and put a paperclip in with a 45 degree bend on the end and ive tried turning clockwise and anti clockwise and nothing
if you still carnt im afraid its the whole steering lock couling off. remove the plastics,steering wheel. youl see a silver/gfrey shroud round the shaft. on the top is two snap bolts with no head obvisously. make a gash in them with a sharp metal chisel then tap them round till they come out. replace the whole bottom halft including steering lock with a one from scrappy.
you could get new bolts of you could tap the ones you took out back round
Let your missus or someone else have a go. Sometimes these things are like crosswords and you have to take a step back or ask someone else who isn't as driven to get it sorted!
Discussion Starter #11
True and I do have a pull hammer :D
1 - 11 of 11 Posts
