the cars had a bit of a starting issue lately, just noticed that fiddling with the cam sensor plug made it start, with a noise,(no5 injector) so switched off, and back on again and it ran fine. still has this intermitant fault. is it likely to be the sensor at fault or bad wiring? is it common for the wiring to go bad here?
Discussion Starter #2
ok so i guess the sensor is goosed. i will order one up. i was going to get one a while back but it seemed to get better.
i have also noticed the rev counter kinda flickers does that point to cam sensor as well?
managed to find a guy breaking a touring with 86k on the clock, running perfect. cat c right o0ff, on e bay 25 quid for cam and crank sensors both genuine.:D i think i'll chance going second hand for 25 notes.
