Im hoping for some help :-
Went to have a loud exhaust problem investigated last week, ATS said that the back box was useless and that the exhaust manifold to centre section only had 3 studs, the 4th being broken, which would need to be sorted at some point.....
Changed the back box and the exhaust is much quieter, still quite loud from start up, but does quieten down quite a bit after a few mins
Anyway, decided today to get the stud drilled out at a local "non" bmw garage, they reckoned that the blow was at the manifold, however, they couldnt find the blow, but, did say that it was not leaking at the downpipe/front section joint (where there are only 3 studs)
I have been reading about problems with the manifolds on 318is's, I am assuming this could also apply to my vehicle (reg 15/9/95)
Should I take the car to a BMW specialist before spending on on a manifold ?
Also any help on where to source a manifold would be appreciated
