Okay to cut a long story short I am in hospital (long term) and my wife has broken her car today
It is a 1995 318is coupe a lovely car, passed its MOT yesterday with no advisories, has a spinning ignition barrel which we do not notice ever anymore due to knowing what to do to avoid it.
Somehow on the way home from hospital this morning two things seem to have happened.
1) she broke the alarm fob, the only one we have the back is broken off it.
2) the passenger window has come out of its sliders.
now my neighbour has kindly jammed the window shut, until I will be in such a position as to spend maybe hours taking the door completely apart etc etc.
The alarm fob does work if it is held together in the right place, therefore it could maybe be tapped up, but apparently the button is not working very often and I am concerned about it breaking when she is out. I did try and get a replacement fob but BMW said it is a sigma alarm fob and they cannot source them anymore. It did have a little sticker with 115 inside the back, I remember seeing it before.
The problem is that because the window is broken the sensors think the window is open so everytime the alarm fob is used it tries to close the windows and makes a terrible crunching noise whilst the motor is turning thinking it is shutting the window.
I would like to get her into a position where she can simply use the key to open and run and lock the car.
currently if she uses the key to open the car it does not start unless she then switches the alarm on then off again, I am sure I remember seeing instructions in the manual on how to disable the immobiliser, If I remember this takes a long time to complete but is an easy enough task to do.
Can anyone shed any light on whether this is the case, or does the sigma alarm mean it is not using the bmw immobiliser?
Any instructions would be gratefully received and I can speak to my wife and next door to see if they can sort it out between them, currently it is in a position where it still runs so if it is going to be a real struggle I can still get my dad to drive it to a bmw garage instead.
Thanks in advance...
Sorry I know it is a long message ( that'll be the morphine
Simple request, can I get some guidance on disabling the fitted immobiliser if it has a sigma alarm, we have plenty of time, the working alarm fob, and the car keys the car currently starts and runs and the alarm fob disables the immobiliser okay.
if anyone can throw in some guidance surrounding the passenger window not being in the rails etc, we have a haynes manual but it seems quite complicated by what I have been told.
Thanks Again
Thanks Again
