1 - 1 of 1 Posts
Hi all,
I've recently finished getting a Eaton M62 charger mounted on my 318IS M42 engine, it runs ok but it doesn't idle that great and needs the map tweaking. Does anyone have a base map .msq file for a M42 on an MS3X that I could use as a starting point to tune from? Or could you point me in the direction of the best person to speak to, I have the tunerstudio set-up and running well but figured it would save a lot of ground work if anyone has already created a start point...
Thanks in advance for any input
Hugo
1 - 1 of 1 Posts
